Forum Audiophonics.fr
Forum du site de vente en ligne Audiophonics.fr : Pour les amateurs de Home Audio, de Connectique et de DIY
Nous sommes actuellement le Jeu 24 Mai 2018 16:42
Le fuseau horaire est UTC+1 heure
Publier un nouveau sujet Répondre au sujet  [ 81 message(s) ]  Aller vers la page Précédent  1, 2, 3, 4
Auteur Message
Message Publié : Mar 25 Avr 2017 14:00
Hors-ligne
Message(s) : 22
I have got Moode 3.5 looking pretty good on the RPI touchscreen. Rather than try to edit the css of Moode (I have no skill in this) I just added a couple of Chromium extensions to shrink it and remove the scrollbar. The extensions were Zoom and Minimal Scrollbar.
I haven't worked out how to get the matchbox-keyboard working yet but have found some guides so I should be able to do it.
I will reinstall it again when Moode 3.6 comes out shortly and hopefully do it smoother next time. If I think I have a clean install, I will write up a guide.
Haut
 Profil
Message Publié : Mar 25 Avr 2017 16:32
Hors-ligne
Avatar de l’utilisateur
Message(s) : 21
Thank you morias, I will follow this subject very carefully.
See you soon
Pibill
Haut
 Profil
Message Publié : Dim 30 Avr 2017 13:53
Hors-ligne
Message(s) : 22
These are some instructions to get the screen going. To get the power button working, have a look at the Raspdac instructions. I have given up on the matchbox-keyboard for the moment. If Audiophonics comes back to these forums, perhaps they could post some instructions. I think it may be something to do with the "focus" setting in the Customize page of Moode.
My instructions are largely based on the good work on this page so credit goes to the author:
https://rataks.com/blog/raspberry-pi-to ... omium.html
Step 1 - Prepare your sd card
Write moode to your sd card
Go to http://moode.local
Go to configure system and choose to expand the sd card
Step 2 - Fix screen orientation
ssh pi@moode.local
sudo nano /boot/config.txt
Now add the following to the bottom of the config to rotate the screen
lcd_rotate=2
avoid_warnings=1
Step 3 - Install software
sudo apt update
sudo apt install xinit xorg lsb-release xserver-xorg-legacy chromium-browser
sudo sed -i "s/allowed_users=console/allowed_users=anybody/" /etc/X11/Xwrapper.config
Step 4 - Create a .xinitrc file
sudo nano /home/pi/.xinitrc
Add the following to the fie and save it
#!/bin/bash
# turn off display power management
xset -dpms &
# turn on a 10 minute screensaver
xset s 600 &
# start chromium browser
chromium-browser --kiosk --touch-events --disable-touch-drag-drop --disable-overlay-scrollbar --enable-touchview --enable-pinch --window-size=800,480 --window-position=0,0 --disable-session-crashed-bubble --disable-infobars --no-first-run --app=http://localhost/
Step 5 - Create a start-gui.sh file
sudo nano /home/pi/start-gui.sh
Add the following to the file and save it
#!/bin/bash
/usr/bin/xinit
Make executable by running the following
sudo chmod +x /home/pi/start-gui.sh
Step 6 - Create a service
sudo nano /lib/systemd/system/start-gui.service
[Unit]
Description=Start Chromium GUI
After=nginx.service php5-fpm.service mpd.service
[Service]
Type=simple
ExecStart=/home/pi/start-gui.sh
User=pi
[Install]
WantedBy=multi-user.target
Step 7 - Start the service
sudo systemctl enable start-gui.service
sudo systemctl start start-gui.service
Step 8 - Modify the look of the interface
Press Ctrl tab on a keyboard connected to the Raspberry pi
Go to Chromium advance settings and set the default zoom to 75%. This can be modified to something else by "inspecting" the element. Look online for guides.
Go to Chrome extensions (chome://extensions) and install minimal scrollbar
To hide the cursor make sure the nocursor flag is now included
#!/bin/bash
/usr/bin/xinit -- -nocursor
The display should now be working
Haut
 Profil
Message Publié : Jeu 04 Mai 2017 08:13
Hors-ligne
Message(s) : 21
ssh pi@moode.local
lcd_rotate=2
avoid_warnings=1
sudo apt update
#!/bin/bash
xset -dpms &
xset s 600 &
#!/bin/bash
/usr/bin/xinit
[Unit]
[Service]
Type=simple
User=pi
[Install]
#!/bin/bash
Thank you for all those informations. I will try to make these changes when I return to my home. I hope version 3.6 that I will acquire will not pose a problem.
Cordially.
Haut
 Profil
Message Publié : Jeu 04 Mai 2017 09:29
Hors-ligne
Message(s) : 22
Cordially.
The instructions were prepared using version 3.6.
It should work for any version and is unlikely to break based on Tim's updates.
Haut
 Profil
Message Publié : Sam 08 Juil 2017 12:29
Hors-ligne
Message(s) : 22
I had cause to reinstall this on a new device. This time I added the "Virtual Keyboard" chromium extension.
I now have a nice onscreen keyboard if I want to do a search.
Haut
 Profil
Afficher les messages publiés depuis :  Trier par
Qui est en ligne ?
Utilisateur(s) parcourant ce forum : Aucun utilisateur inscrit et 1 invité
Vous ne pouvez pas publier de nouveaux sujets dans ce forum
Vous ne pouvez pas répondre aux sujets dans ce forum
Vous ne pouvez pas éditer vos messages dans ce forum
Vous ne pouvez pas supprimer vos messages dans ce forum
Vous ne pouvez pas insérer de pièces jointes dans ce forum
Recherche de :
Aller vers :
Propulsé par phpBB® Forum Software © phpBB Group
Traduction et support en français • Utiliser phpBB avec un certificat SSL
