Forum Audiophonics.fr
Forum du site de vente en ligne Audiophonics.fr : Pour les amateurs de Home Audio, de Connectique et de DIY
Nous sommes actuellement le Ven 19 Oct 2018 13:52
Le fuseau horaire est UTC+1 heure
Publier un nouveau sujet Répondre au sujet  [ 1 message ]
Auteur Message
Message Publié : Mar 25 Sep 2018 10:06
Hors-ligne
Message(s) : 1
Hi all
I received my 'AUDIOPHONICS RaspDAC I-Sabre ES9038Q2M V2' (link) last week.
I started with the (purchase/provided) volumio instance, worked well, but the screen would only work for a while - always starts fine, then runs for between 15 and 45 minutes before it just turns off. The only way to restore it is to restart the pydPiper service, after which it works for another 15-45 minute period.
I decided to play around with moOde, which I've now built, and managed to get all the kernel modules, power button etc working as intended, and installed pydPiper from (link), using the install_docker.sh script and modifying the pyPiper.cfg and pydpiper.service files to match the setup provided by the audiophonics volumio SDCard.
I have the same problem though, screen works, until it doesn't.
There is nothing in the system log to indicate an error (I have debug logging enabled), it just cycles through the system status messages at the point I see it turn off...
Code :
2018-09-25 07:19:33,680:DEBUG:System status: Temp 47°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:24:33,734:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:29:33,781:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:34:33,834:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:39:33,890:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:44:33,942:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:49:34,001:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
2018-09-25 07:54:34,059:DEBUG:System status: Temp 45°c, Disk space remaining 86%, IP address 192.168.1.57
etc.
The pydpiper.service does not crash and continues to run. Docker throws no errors, the screen just stops working.
I've established it's not volumio or moOde, and I assume the config provided by audiophonics works as expected - does anyone else have this issue or ideas about it before I go back to them around a (potentially?) faulty screen or whatever it's plugged into inside?
Thanks!
Haut
 Profil
Afficher les messages publiés depuis :  Trier par
Qui est en ligne ?
Utilisateur(s) parcourant ce forum : Exabot [Bot] et 1 invité
Vous ne pouvez pas publier de nouveaux sujets dans ce forum
Vous ne pouvez pas répondre aux sujets dans ce forum
Vous ne pouvez pas éditer vos messages dans ce forum
Vous ne pouvez pas supprimer vos messages dans ce forum
Vous ne pouvez pas insérer de pièces jointes dans ce forum
Recherche de :
Aller vers :
Propulsé par phpBB® Forum Software © phpBB Group
Traduction et support en français • Utiliser phpBB avec un certificat SSL
