Connect I2S to I-Sabre ES9038Q2M
mikeDIYaudio
Message par mikeDIYaudio » ven. 04 déc. 2020 15:37
Hi,
The Audiophonics I-SABRE ES9038Q2M DAC has a lot of connectivity - but has anyone connected an I2S output to the DAC ?
I'm thinking of buying the CS8416 Source Selector Module (2 SPDIF Inputs to 1 I2S Output), but the I2S output from the CS8416 [SCLK/SDATA/LRCK/MCLK] doesn't seem to match the ES9038Q2M inputs. Should I buy a different SPDIF source selector module ? I want to connect my CD player to the DAC. There doesn't seem to be a way to connect RCA output from the CD player to the DAC, but there are a couple of SPDIF to I2S modules, and my CD player has an optical SPDIF output.
Thanks
Re: Connect I2S to I-Sabre ES9038Q2M
Message par Audiophonics » ven. 04 déc. 2020 16:16
Hi,
Thanks
Hi,
You already have an SPDIF input on this board you only need to add a connector and a push button to switch from I2S to SPDIF ex :
mikeDIYaudio
Message par mikeDIYaudio » ven. 04 déc. 2020 16:27
Hi David,
I saw the SPDIF connection on the DAC, but don't know how to connect the optical TOSLINK cable from the CD player. Do you sell the kit I'd need ?
Thanks
Message par Audiophonics » ven. 04 déc. 2020 16:36
Hi David,
Thanks
You can keep it simple ex :
https://www.audiophonics.fr/en/optical- ... 13412.html
mikeDIYaudio
Message par mikeDIYaudio » ven. 04 déc. 2020 17:15
Thanks,
I was looking at DIY kit which is probably why I didn't spot this when searching your shop.
And it's simple enough for me :-D
