RaspDac / Rasptouch - Custom images
Ici on parle de Raspberry PI, Sparky, Odroid... avec des solutions comme Squeezelite, MPD, Max2Play... ainsi que leur DAC et accessoires dédiés
kjarrig
Re: Rasptouch modded audio software / Solutions audio modées
Message par kjarrig » mer. 08 févr. 2017 10:04
Hi,
I've tried Volumio, and Volumio plays 24 bit files, but not 16 bit files. See thread viewtopic.php?f=12&t=1756" onclick="window.open(this.href);return false;, there's a user working on this problem regarding the 16 bit files. I installed PiCore player, and I prefer the Picore player instead of RuneAudio, but would like to have Volumio, so I'm waiting for his solution. As you can see in viewtopic.php?f=12&t=1756
Iznogoud
Message par Iznogoud » mer. 08 févr. 2017 11:16
kjarrig a écrit :Hi,
Since yesterday evening, I have a full working Rasptouch with ES9018K2M working on Volumio 2.041.
This includes :
- 24 bits MP3 files playing
- Spotify 16 bits stream playing through Volumio Spotify plugin
- Spotify Connect function through Volumio Spotvolconnect plugin
- web radios playing
- full control of the DAC hardware volume through the touchscreen
- power supply management (hardware push button and UI)
- mouse cursor hiding on touchscreen
Now, I need time to write the full, quite long, procedure.
Keep watching !
kjarrig
Message par kjarrig » mer. 08 févr. 2017 11:58
This is great news, and I will be watching.
mrfunk
Message par mrfunk » mer. 08 févr. 2017 22:18
Hi, Im using the moode raspTouch image
THANKS ! this is awesome with the 7 inch screen
how do adjust the screen =saver time out? or cace screen saver altogether?
would be awesome to light screen up on track change.
many thanks
Funk
morias
Message par morias » mer. 15 févr. 2017 23:03
Is it possible for you to post a tutorial on how to modify the Moode distribution for the Rasptouch?
I really appreciate you making an image but the software is usually updated monthly so I would like to know how to update it to use the touchscreen so I can stay up to date.
I think your image is for 3.0 and 3.2 is due out shortly.
GuillaumeSej
Message par GuillaumeSej » dim. 26 févr. 2017 15:48
Je tourne toujours sur l'image v0.4 de RuneAudio que vous avez mise en ligne, et je me demandais si les sources pour cette version avaient finalement été poussées sur un repository GIT quelque part ?
D'autre part, je cherche a desactiver le screensaver que vous avez ajoute (je vois pas trop pourquoi c'est par défaut....) et impossible de trouver d'options correspondantes dans les fichiers de conf (et je parle pas de l'interface...)
Pourriez-vous m'éclairer svp ?
Merci d'avance,
Registration
Message par Registration » mar. 28 févr. 2017 22:49
ES9018K2M
everytime changing manually to next or last song i hear short crackling. (moode and rune audio)
everything else, except hardware volume is ok
i also bought Audiophonics I-ES9023 Sabre DAC V3 TCXO Raspberry Pi 2,0 A + B + / I2S
there is no such problem with that dac.
so, is it a software or hardware problem.
Iznogoud
Message par Iznogoud » dim. 05 mars 2017 18:33
kjarrig a écrit :This is great news, and I will be watching.
See here
I will publish power supply management tutorial and mouse cursor hidding tutorial later.
kjarrig
Message par kjarrig » mar. 21 mars 2017 19:44
Does anyone have a picture of the ES9018K2M in hardware mode? I'm not sure how to have the DAC in hardware mode.
Iznogoud
Message par Iznogoud » mar. 21 mars 2017 20:34
kjarrig a écrit :Does anyone have a picture of the ES9018K2M in hardware mode? I'm not sure how to have the DAC in hardware mode.
Here, bottom picture.
kjarrig
Message par kjarrig » mer. 22 mars 2017 00:26
I've seen that one but my thick head doesn't understand so I was hoping to see a picture of the DAC with the jumper in place
Iznogoud
Message par Iznogoud » mer. 22 mars 2017 09:45
kjarrig a écrit :I've seen that one but my thick head doesn't understand so I was hoping to see a picture of the DAC with the jumper in place
There are two jumpers (wires) to put in place:
- one between J1-2 and J4-1 (pin #1 is always the square one)
- one between GPIO Tx output and the microcontroller Rx input (U9 pin #11, square pad)
Notice the microcontroller needs to run the right software to work in hardware mode. According to Audiophonics comments, only DACs manufactured since beginning november 2016 embed this software. For older DACs, especially ones delivered to Rasptouch backers, they need to be updated in Audiophonics workshop.
morias
Message par morias » jeu. 13 avr. 2017 11:35
morias a écrit :Is it possible for you to post a tutorial on how to modify the Moode distribution for the Rasptouch?
Just a bump for a tutorial on modifying Moode for the touchscreen. Version 3.5 of Moode is due for release this month.
Avatar de l’utilisateur
rikardo1979
Contact :
Message par rikardo1979 » mar. 18 avr. 2017 08:10
I can not wait for this :) It have been announced long ago. I am ready to update my Mo0deAudio thread once released ;)
~~~~>>>Please always follow rules and read before you post<<<~~~~
rikardo1979
Contact :
Message par rikardo1979 » mer. 19 avr. 2017 10:10
looks that Mo0deAudio is not free anymore :roll: :| There is a minimum $10 donation req to get the code to unpack zip. And its not one of payment!
Each major release will cost money!
morias
Message par morias » mer. 19 avr. 2017 22:53
rikardo1979 a écrit :looks that Mo0deAudio is not free anymore :roll: :| There is a minimum $10 donation req to get the code to unpack zip. And its not one of payment!
I have version 3.5. I just need to know how to modify it to activate the touchscreen on the Rasptouch before I can use it.
I hope I don't need to go back to Runeaudio as I prefer Moode.
It has been pretty quiet in this thread with no recent news from Audiophonics. I hope you guys get time soon to set out the upgrades you did to get the touchscreen working.
rikardo1979
Contact :
Message par rikardo1979 » jeu. 20 avr. 2017 06:07
I dont think so they will start releasing Mo0deAudio with built in scrips cos now you have to pay for it! So they simply can not do it.
So I am afraid you have to do it yourself or you are out of luck with this OS
pibill
Message par pibill » jeu. 20 avr. 2017 07:58
Hello,
I would also like to test MoOde on my Rasptouch, a modest contribution does not bother me, however I'm not sure I get a fully operational system; I do not possess the capabilities to modify the software in depth.
Cordially
Pibill
rikardo1979
Contact :
Message par rikardo1979 » jeu. 20 avr. 2017 18:32
With MoOdeAudio is what it is from now as the maintainer starts charge for it. So Audiophonics would have to pay a licence or something to be able to re-sale modified version of it. And I dont see this will ever happen.
We have some How-to threads here which you can try to follow to modify the system to add the scripts for PWR+DISPLAY
I am afraid there is no any other way, unless you ask the guy from behind MoOdeAudio to add the scripts and release a special version which you can than buy of him
morias
Message par morias » ven. 21 avr. 2017 14:41
rikardo1979 a écrit : I dont think so they will start releasing Mo0deAudio with built in scrips cos now you have to pay for it! So they simply can not do it.
I think Audiophonics could write a "how to" without releasing an image.
In any event I had a look at Audiophonics modified Moode and think I can make my own modified version 3.5.
Hopefully I will get time to do it on the weekend. If I do I will write up how to do it.
morias
Message par morias » sam. 22 avr. 2017 14:58
I got it working with Moode 3.5, largely by following the Rataks guide for getting the touchscreen working for Moode.
I have made it fit fairly well however I haven't managed to eliminate the side scrollbar yet. I think Audiophonics set a custom zoom and also modified the css to make it fit better.
If anyone from Audiophonics is reading this and can post what was changed, that would be much appreciated.
pibill
Message par pibill » sam. 22 avr. 2017 16:31
morias a écrit :I got it working with Moode 3.5, largely by following the Rataks guide for getting the touchscreen working for Moode.
Hello,
@ Rikardo1979
I agree with you. The RASPTOUCH (9018) is a good product, it possesses an important evolutionary potential that could make it even better. I have great esteem for the Audiophonics team, however I do not understand their forward approach to this series of products they have fully designed.
Editing a script, I know how to do, is the minimun for DIY. Design not.
Contacting the Moode designer could be the right solution, provided the demand is significant. Note that Runeaaudio, advised by Audiophonics, works rather well. I want to ask the question, but if I am the only interested ???
@ Morias
Thank you for your investment, it seems very promising.
Best regards.
Registration
Message par Registration » dim. 23 avr. 2017 12:36
I contacted Tim Curtis (http://moodeaudio.org/" onclick="window.open(this.href);return false;)
His answer:
I don’t have any experience integrating locally attached screens and Moode has never provided built-in support for locally attached screens, power buttons and similar peripherals.
What happens is that users modify Moode to support their particular screen or power button. I’m sure someone will figure out how to do this on Moode 3.5.
rikardo1979
Contact :
Message par rikardo1979 » dim. 23 avr. 2017 18:06
Yes,
Tim always said he will not provide any support and custom modify his system to work with HW he does not have and can not test!
pibill
Message par pibill » lun. 24 avr. 2017 08:39
rikardo1979 a écrit :Yes,
In other words, Tim is not opposed to individual contributions.
Pibill
Répondre
