GPIO-Pins a Sabre V3
Fourever
Message par Fourever » mer. 28 déc. 2016 13:15
As my french is very bad i translated my question with google:
Bonne journée!
Pour connecter un récepteur infrarouge au Sabre DAC V3, je besoin d'informations qui GPIO broches qui sont sur la carte disponible. Malheureusement, les instructions pour Sabre V3 ne permet pas.
Merci!
Fourever
<<<<<<<<<<<<<<<in english>>>>>>>>>>>>>>>>>
I bought a Sabre V3 and want to use a IR-Commander with lirc. I found no informations, whitch GPIO-Pins are the right to connect a TSOP 4838 with the DAC. The case i have is this one http://www.audiophonics.fr/fr/boitiers- ... 11138.html" onclick="window.open(this.href);return false; . It has a hole for the TSOP.
Thank you!
Fourever
Re: GPIO-Pins a Sabre V3
Message par Audiophonics » mer. 28 déc. 2016 13:39
Désirez vous utiliser l'une de nos images moddées disponibles ici :
viewtopic.php?f=4&t=1777
Dans l'attente de vous lire.
Hi,
have you planned to use one of our modded releases available here ? :
Looking forward to hearing from you.
Fourever
Message par Fourever » mer. 28 déc. 2016 14:39
Sorry,
i think, my description was incorrect...
I'm using picoreplayer and want to attach a IR-Commander, using a TSOP 4338. This IR-Receiver has 3 pins to connect (5V, Ground and output). These pins have to be connected to the GPIO of the Raspberry whitch are blocked / used by the Sabre V3.
So the question is, which Pins on the Sabre V3 can be used for connecting the IR-Receiver.
On the Sabre i can solder on the GPIO-Pins which are connected withe the Raspberry. Or there is a not described Pinout, labelled with "Prog". There are also 4 unused Pins at the Header, where the OLed ist connected.
In the configuration of lirc i can say, which GPIO-Pins is used for the IR-Receiver, but which Pin can i use?
Hope, this description is better to understand...
Regards
Fourever
<<<<<<<<<<<<<<< Translation to french by Google>>>>>>>>>>>>>>>>
785/5000
Ausgangssprache: Englisch
Désolé,
je pense, ma description était incorrecte ...
J'utilise picoreplayer et que vous voulez joindre un commandant IR, en utilisant une TSOP 4338. Ce récepteur IR a 3 broches pour connecter (5V, sol et sortie). Ces broches doivent être reliées au GPIO du whitch framboise sont bloqués / utilisés par le sabre V3.
Donc la question est, qui broches du Sabre V3 peuvent être utilisés pour connecter le récepteur IR.
Sur le Sabre je peux souder sur les broches GPIO sont reliées withe la framboise. Ou il y a un brochage pas Décrite, marqué avec "Prog". Donc, Il y a 4 broches inutilisées à l'en-tête, où l'OLED est connecté.
Dans la configuration de lirc je peux dire, Quelle broche GPIO est utilisée pour le récepteur IR, mais dont la broche puis-je utiliser?
Espérons que, cette description est préférable de comprendre ...
Fourever
Message par Audiophonics » mer. 28 déc. 2016 14:44
you can use the regular IR pins, I-Sabre V3 is using the same pinout has Hifiberry DAC.
more here :
http://forums.slimdevices.com/showthrea ... coreplayer
