I-Sabre kali editio and Allo kali reclocker ( DAC ) Rpi3
foxgenco
Message par foxgenco » ven. 20 oct. 2017 05:20
¿does anyone know how to run the 384 khz or 192 khz using Kodi 15.2 under Raspbian Jessie?
because only displayed on the i-sabre screen 96kHz, while listening to a 384kHz,192 kHz, 176 kHz Flac audio file.
also only the 96kHz led is on under Allo kali reclocker
components:
AUDIOPHONICS DAC I-SABRE ES9028Q2M KALI EDITION
ALLO KALI RECLOCKER I2S FIFO
RASPBERRY PI 3
in the file config i have the line dtoverlay=hifiberry-dac
Re: I-Sabre kali editio and Allo kali reclocker ( DAC ) Rpi3
Message par Audiophonics » ven. 20 oct. 2017 08:19
Hi,
Kodi under Raspbian is not a bitperfect audio system.
You'll be limited by the audio mixer settings under debian.
You can achieve 32/384khz with an advanced kernel and bitperfect software like Moode Audio, Picoreplayer etc ...
foxgenco
Message par foxgenco » sam. 21 oct. 2017 06:58
well yes, in other distributions like those that you mention works, but I would like to have it work on my already made configuration, since I have customized the whole system.
it seems to have to modify the kernel to be able to add the support of the DAC in debian 8,9 (jessie, stretch) because the dietpi already have integrated the support in the same kernel (4.9xx) , although using their files http://dietpi.com/downloads/binaries/rp ... naries.zip does not work.
foxgenco
Message par foxgenco » sam. 21 oct. 2017 09:24
well, i fixed now. just used the Kernel from DietPi 4.9.52-v7+ http://dietpi.com/downloads/binaries/rp ... el_4.9.zip and the i-sabre drivehttp://dietpi.com/downloads/binaries/rp ... naries.zip from same site.
now works 352.8 Khz on Kodi 15.2 and Debian 8 (jessie) ( or whatever you use )
for check on command the actual info of hardware of dac play
Code : Tout sélectionner
cat /proc/asound/card*/pcm0p/sub0/hw_params
command used:
sudo apt-mark hold raspberrypi-bootloader raspberrypi-kernel libraspberrypi-bin
wget http://dietpi.com/downloads/binaries/rpi/dietpi_rpi_kernel_4.9.zip -O package.zip
sudo 7z x -aoa package.zip -o/
rm package.7z
wget http://dietpi.com/downloads/binaries/rpi/I-Sabre-K2M_binaries.zip -O package.zip
sudo unzip -o package.zip -d /
rm package.7z
depmod -a
code added on boot/config.txt
dtoverlay=i-sabre-k2m
dtparam=i2c_arm=on
Message par Audiophonics » lun. 23 oct. 2017 08:49
Hi,
Yes you're right it seems to be a kernel related issue.
Thanks a lot for sharing your work with the community.
What do you think of the DAC sound ?
Looking forward to hearing from you.
