How to eliminate flashing light led button on / off
Rodotech
Message par Rodotech » sam. 06 janv. 2018 22:12
Hello friends,
I need to know in what way I can eliminate the flashing led light of the ignition button (on / off), since once turned on, the light is blinking.
I use it with a dac i- saber v3- raspberry pi, SO volumio.
Stay tuned to your comments.
thank you very much.
fengalin
Re: How to eliminate flashing light led button on / off
Message par fengalin » mar. 09 janv. 2018 11:52
Hi Rodotech,
You may want to try this: https://github.com/JedS/Raspdac
Alternatively, this should also do the job: https://github.com/fengalin/raspdac-on- ... is-project
Let us know how it went!
Message par Audiophonics » jeu. 11 janv. 2018 17:59
Rodotech a écrit :Hello friends,
Under Volumio, you just have to use the "Raspdac V3 Plugin"
Like described here :
https://volumio.org/forum/volumio-plugi ... t6251.html
Feel free to ask us any questions needed.
Rodotech
Message par Rodotech » sam. 13 janv. 2018 03:59
thank you very much guys, problem solved.
Rodotech
Message par Rodotech » sam. 13 janv. 2018 04:00
fengalin a écrit :Hi Rodotech,
thank you very much , problem solved.
:-D
