A modern approach to power control on the RaspDAC
unhold
Message par unhold » ven. 29 juin 2018 20:33
Hi fellow audiophiles!
I recenty bought the RaspDAC I-Sabre V4 DIY Kit and I like it very much. What a nice piece of hardware!
However, I was less happy with the power control and the scripts to use it. The timeout approach seems outdated.
So I created my own solution, and I want to share it with you today:
I wrote a new firmware for the ATtiny45 on the RaspDAC that works with the new Linux drivers gpio-shutdown and gpio-poweroff.
https://github.com/unhold/avr/tree/master/src/raspdac
I attached a built version for 1 MHz clock frequency, the default for the ATtiny45.
Note that the original RaspDAC uses the #RESET pin (top left) as GPIO, so they had to fuse the RSTDISBL fuse. You will need a High-Voltage Serial Programmer or a new ATtiny45. You have to burn the RSTDISBL fuse or bend/cut the #RESET pin. I don't use it in my firmware.
unhold-raspdac-1MHz.zip
ATtiny firmware for 1 MHz clock (default)
(802 octets) Téléchargé 78 fois
Flash it on your ATtiny, then put this into your Raspi /boot/config.txt:
Code : Tout sélectionner
dtoverlay=gpio-shutdown:gpio_pin=17,active_low=0
dtoverlay=gpio-poweroff:gpiopin=22
On some images (e.g. Volumio 2) you have to put this into the new file /etc/udev/rules.d/30-shutdown.rules:
ACTION!="REMOVE", SUBSYSTEM=="input", KERNEL=="event*", \
	SUBSYSTEMS=="platform", DRIVERS=="gpio-keys", \
	ATTRS{keys}=="116", TAG+="power-switch"
Benefits:
  • Immediate poweroff after Raspi finished shutdown,
    Works with every (reasonable up-to-date) Raspi Linux image,
    Easy to configure,
    Works with any shutdown option (shutdown, halt, from GUIs, etc.).
Let me know what you think of it!
Cheers and happy listening
unhold
Dernière modification par unhold le mer. 28 nov. 2018 11:36, modifié 1 fois.
Mathys
Re: A modern approach to power control on the RaspDAC
Message par Mathys » lun. 09 juil. 2018 17:09
Merci pour le partage de cet astuce unhold. Je prévois moi aussi de tester RaspDAC, et c'est sûr que j'aurai besoin de ce petit guide pour faire ma configuration et mon installation. La plupart du temps je galère dans ces choses là :lol:
