ADAU1701 and AA-AB41133 S/PDIF Coaxial to I2S WM8804
TR_HH
Message par TR_HH » lun. 03 févr. 2020 11:19
Hey together,
I want to connect my sure dsp adau1701 via I2S with the Wondowm AA-AB41133 S7PDIFto I2S Interface card.
Has someone of you done this successfully?
If yes, I will be very interested which settings you used on both sides.
I use the sure-dsp as master with 96khz and 24 bit resolution and the wondowm Interface board as slave.
(The Sure Dsp works already fine which I tested by using an digiout channel with a generated sinus signal as source for an other digin channel)
But both together connected don't work. So there must be some failures in settings. In the evening I will place here more pictures of my settings.
download/file.php?mode=view&id=831
Thank you in advance
Warm greeting from Hamburg
Thomas
TR_HH
Re: ADAU1701 and AA-AB41133 S/PDIF Coaxial to I2S WM8804
Message par TR_HH » jeu. 02 avr. 2020 11:14
Personne qui a de l'expérience avec ça?
